GS1 128 Barcode
Posted: Wed May 10, 2017 1:13 pm
by ArnaudS
I'm trying to create a GS1-128 Barcode with the symbologie indentifier "]C1" and 12 character.
But i can't find the write syntax.
I'm using VB.NET and I have try this:
'pWriter is a BarcodeWriter
'pText is my codebar value
Dim lsi As New GS1_128BarcodeSymbology()
 pWriter.Settings.ValueItems = New ValueItemBase() {New TextValueItem(pText)}
lsi.Encode(pWriter.Settings.ValueItems.First(), pWriter.Settings)
lEncoddeText = lsi.ToString()
Also try this, but the AI appears in the final codebar :
Dim aiValues As GS1ApplicationIdentifierValue() = New GS1ApplicationIdentifierValue(0) {}
Dim ai  As GS1ApplicationIdentifier = GS1ApplicationIdentifiers.FindApplicationIdentifier("10")
aiValues(0) = New GS1ApplicationIdentifierValue(ai, pText)
Dim lGsi = New GS1ValueItem(aiValues)
lsi.Encode(lGsi, pWriter.Settings)
lEncoddeText = lGsi.PrintableValue
have anyone a hint or a sample ?
Thanks in advance.
Arnaud
Re: GS1 128 Barcode
Posted: Wed May 10, 2017 2:19 pm
Hi Arnaud,
Please see example here:
https://www.vintasoft.com/docs/vsbarcod ... Codec.html
Re: GS1 128 Barcode
Posted: Wed May 10, 2017 2:42 pm
by ArnaudS
Thank's you for your reply but i still have a problem, the sample don't show how to remove the 'AI' from the readable barcode.
I don't wan't to show the 'AI' in the code barre.
Is there a way to encode As a GS1 128 and don't show up the ApplicationIdentifier ?
Re: GS1 128 Barcode
Posted: Wed May 10, 2017 4:49 pm
Do you want to write the GS1 value directly to the barcode? If yes, you need create Code128 barcode and write the GS1 value.
