Support for transparent background in .png format image
Posted: Thu Feb 26, 2015 12:30 am
by emlarsen
Does VintaSoft Imaging support png files with transparent backgrounds? I have an older version and it load the file just fine but after a resize the background is black. Do I need to handle this in code or do I need a newer version?
Re: Support for transparent background in .png format image
Posted: Thu Feb 26, 2015 10:20 am
Hello Mark,
Yes, current version supports transparency in PNG images.
Please download the evaluation version of SDK from our web site:
http://www.vintasoft.com/zip/VSImagingNet81.zip
evaluate it, make sure it suits your needs and only then renew subscription for your license.
Posted: Fri Jun 09, 2017 9:40 am
by DuempertM
We have a little problem with a PNG File.
This File have a tranparency background and when i save it to a JPG File is the background black.
How can I determine the transparency in C # and save the tranparent color to a JPG File.
I hope you can help me with an example
Greetings
Posted: Fri Jun 09, 2017 10:11 am
JPEG image does not store information about transparency because JPEG file can store only 24-bpp RGB image or 8-bpp grayscale image.
Posted: Fri Jun 09, 2017 10:31 am
by DuempertM
That is clear.
Let's take a PNG file with a transparency. The color is white.
I am looking for a way to save this file as a JPG file with a white background.
Is that possible ? And if so how?
If I open the file for example with IrfanView and save as JPG, the background is also white and not black.
Posted: Fri Jun 09, 2017 2:27 pm
Irfan replaces the transparent color to the white color before image saving. And I think Irfan uses white color because white color is specified as the background color in Irfan settings.
For solving your task you need to do the following steps:
Posted: Fri Jun 09, 2017 4:25 pm
Also for solving your task you can create a temporary empty image, fill temporary image with white color, draw PNG image on temporary image and save temporary image in JPEG file.
