WinForms - How to continously add Annotations
farangkao
Post by farangkao » Sun Apr 22, 2018 12:57 pm
Hi there,
i'm currently testing your Product as a possible replacement for our old library.
Everything looks very good so far, your Library is really well done.
However i struggle to implement in Code the behavior that we had before:
if the user set a Mode (like "Add Lines") ,he can add lines until he switches the Mode to "Selection" or similar.
I've tried to use the Method PdfAnnotationTool.AddAndBuildAnnotation(annotation);
Which works so far. I figured i call this Method after the Event "BuildingFinished" has fired.
But: When i press Escape and i call the AddAndBuildAnnotation again in Code, the Application crashes.
System.ArgumentOutOfRangeException in Vintasoft.Imaging.dll
I then tried to figure out what circumstances this is comming from.
I noticed that the Event AnnotationViewChanged is called twice with RemoveItem just before the crash.
So i presume that is the root cause.
What is the Proper way ,to achieve my goal, so that the user doesn't has to click the command multiple times to draw/add annotations?
Is there a better Event to subscribe to, so it doesn't interfere with the Interaction?
Re: WinForms - How to continously add Annotations
Post by Alex » Mon Apr 23, 2018 11:29 am
Please send us (to support@vintasoft.com) a small working application, which demonstrates your problem. We need analyze your code.
farangkao
Post by farangkao » Thu Apr 26, 2018 2:30 pm
This has been sucessfully fixed in the newest Version, thanks again.
