performance issue between vintasoft 8 and 10
Posted: Fri Jun 30, 2017 1:23 pm
by Echtelion
I have a performance decrease when upgrading vintasoft.twain from 8.4.0.1 to 10.2.2.1
I have a fast 60ppm scanner (fujitsu fi-7160), doing recto/verso scan in one pass.
cachemode=both, transfermode=memory, color=grayscale
Acquire
The device start scanning fast. After around 25 pages, the device stop scanning fast, and take pages one by one.
The device buffer is probably not flushed fast enough, so the device stop scanning and wait for the buffer to be free.
After analysing, the _device_ImageAcquired is fired way slowly than in the previous version, even if I do nothing in this event.
In 10.2.2.1, event is fired every 1.35sec
In 8.4.0.1, event is fired every 0.8sec
The issue is not present when using transferMode=native (same 0.9sec between events in both versions)
It's hard to see where is the bottleneck, as your assembly are obfuscated.
I can only say there is a lot a Thread.Sleep visible in the profiler.
Thanks for reviewing this issue,
Regards,
Romain Lagrange
Re: performance issue between vintasoft 8 and 10
Posted: Mon Jul 03, 2017 9:44 am
Hi Romain,
I think your problem is related with memory usage. Please check that you disposing the acquired image when image is not necessary any more.
Posted: Mon Jul 03, 2017 3:39 pm
by Echtelion
I'm sorry, but disposing the image didn't change the game.
850ms vs 1311ms
Here is the benchmark :
DateTime lastEvent = DateTime.Now;
List<double> spans = new List<double>();
private void _device_ImageAcquired(object sender, ImageAcquiredEventArgs e)
    DateTime start = DateTime.Now;
    var span = (start - lastEvent).TotalMilliseconds;
    Debug.WriteLine("Start analyze at " + start.ToString("HH:mm:ss.ffffzzz") + ", diff from prev start is " + span + "ms");
    lastEvent = start;
    spans.Add(span);
    if (_parentForm.InvokeRequired)
        _parentForm.BeginInvoke(new Action<object, ImageAcquiredEventArgs>(_device_ImageAcquired), sender, e);
        //benchmark : don't do anything
        //AnalyseAcquiredImage(e.Image);
        // debug only : dispose. discard in prod.
        if (!e.Image.IsDisposed)
            e.Image.Dispose();
    Debug.WriteLine("TaskRun " + DateTime.Now.ToString("HH:mm:ss.ffffzzz") + ", so event take " + (DateTime.Now - start).TotalMilliseconds + "ms to be processed");
    //if (e.EndOfJob)
        Debug.WriteLine("Average span is " + (spans.Sum() / spans.Count) + "ms");
As you can see, I'm just doing nothing but disposing the image, and I still reproduce the issue.
Thanks.
Posted: Tue Jul 04, 2017 11:43 am
Provided code is not enough for understanding the problem. Please create 2 small console applications (for version 8 and 10), which demonstrate the problem, and send your applications to our support at support@vintasoft.com.
Posted: Tue Jul 04, 2017 4:56 pm
by Echtelion
I indeed don't reproduce the issue when starting a new UI from scratch, even with all the device settings being the sames.
This become more and more abscure, as the issue is still here in my "real world app", and the only difference between the two versions of my app is the vintasoft dll.
As the TransferMode=Native fix the issue, it's possible that a garbage collector struggling is a cause...
I'll do additional testings to narrow the root of this issue and will be back if I find something :)
Posted: Wed Jul 05, 2017 9:58 am
Thank you for information. Let me know if our assistance will be necessary.
