(WPF) Large image annotations causing lag
missionRoom
Post by missionRoom »
When I add a large image annotation (approx 1000px x 1250px) to the WpfAnnotationViewer, then save and reload the PDF, I get lag when adding a new annotations. It also seems to happen, when I add a lot of small annotations.
The lag is most obvious when adding a freehand pen annotation, there is a large gap between the first and second point (so it forms a straight line), before it starts behaving normally.
Below is my loading code (not sure if that's the issue, since the lag doesn't happen until the PDF has been saved and re-loaded)?
The image shows the freehand annotations (in red), they all have large straight sections at the beginning, but should have followed the drawn path (that wasn't straight).
https://ibb.co/Cmjk5C7
//Loading PDF file
this.annotationViewer.Dispatcher.Invoke(new Action(() =>
    this.annotationViewer.Image = image;
    //Set the initial zoom
    UpdateZoom(Vintasoft.Imaging.UI.ImageSizeMode.BestFit);
    (ViewManager.Instance.ControlsWindow.DataContext as ControlsWindowVM).MinZoomValue = (float)this.annotationViewer.Zoom;
Thanks for any help
Re: (WPF) Large image annotations causing lag
For understanding the problem we need to reproduce the problem on our side. Please send us (to support@vintasoft.com) a small WPF project, which allows to reproduce the problem.
missionRoom
Thanks for replying.
I've created a simple example, and haven't entirely been able to replicate the issue. But it has helped me work out what's causing the issue, it's the UndoManager/UndoMonitor. I initialise them as below when the image has loaded, if I omit this, then the issue completely goes away.
Is this the correct way to initialise the UndoManager/UndoMonitor? Are there any issues with this that you know of, or anything that could be causing this with relation to the UndoManager/UndoMonitor?
this._undoManager = new UndoManager();
this._undoMonitor = new WpfAnnotationViewerUndoMonitor(this._undoManager, this.annotationViewer);
Thank you for information.
You have delay because an undo manager serializes image in its cache. We improved performance of this process in VintaSoft Imaging .NET SDK 12.2.11.1. What version of VintaSoft Imaging .NET SDK do you use?
missionRoom
I'm using V10.1.16.1, so it sounds like an upgrade may fix our problem.
Thanks for the help
