I'm evaluating VintaSoftPDF for further use.
At the begining I ran into a big problem with OptionalContentGroups.
Task is to create new layer with some text on it in order to recognize (delete or change it) later in lifecycle of the document.
So, in your examples I found how to list and show/hide existing OptionalContentGroups but I don't know how to create new one.
Can You give me some directions or workaround for this quest?
Miki
Adding new OCG (layer) to the page
Re: Adding new OCG (layer) to the page
Hi Miki,
Now it is not possible to create new OptionalContentGroups for PDF. The functionality isn't implemented, but at first glance the implementation could be done rather easy and quickly.
As the need arises, we have added that task in the roadmap for the next version 8.3 of VintaSoft Imaging .NET SDK.
Sincerely,
Yuri
Sincerely,
Yuri
Hi Yuri,
Thank you for your prompt response.
When should I expect the new release?
Miki
Miki
Hi Miki,
AFAIK the plan is to release the version 8.3 of VintaSoft Imaging .NET SDK and Plug-ins until the end of this year.
Kind regards,
Yuri
Kind regards,
Yuri
