Merging Wang-annotated TIFF into jpeg
mbauxd
Post by mbauxd »
Hello people,
I am currently evaluating the Imaging SDK for a project, and have encountered a problem. I load a Wang-annotated TIFF, which shows the annotations in the WPF demo just fine. And then I want to save it, baking in the annotations to the image. But when I open the saved jpg file, the annotations are not in it.
VintasoftImage vsImage = new VintasoftImage(filename);
JpegEncoder je = new JpegEncoder();
je.Settings.CreateThumbnail = true;
je.Settings.AnnotationsFormat = AnnotationsFormat.VintasoftXmp | AnnotationsFormat.VintasoftBinary;
je.Settings.CopyExifMetadata = true;
je.Settings.CopyUnknownApplicationMetadata = true;
je.Settings.CreateThumbnail = false;
je.Settings.GenerateOptimalHuffmanTables = false;
je.Settings.Quality = 100;
je.Settings.SaveComments = true;
je.AnnotationsFormat = AnnotationsFormat.VintasoftXmp | AnnotationsFormat.VintasoftBinary;
string jpegName = String.Format("{0}.jpg", Path.GetFileNameWithoutExtension(filename));
vsImage.Save(jpegName, je);
I read some stuff about SetSaveAnnotaions(true), but that doesnt seem to exist anymore. Anyone here who might be able to help?
Thanks in advance, much appreciated!
Re: Merging Wang-annotated TIFF into jpeg
You have not loaded image and annotations in memory - in this case encoder copies image data without loading the whole image into memory. Also encoder copies annotations as metadata if encoder supports annotations metadata format. JPEG encoder does not support WANG annotations and it does not copies annotations.
For copying WANG annotation from TIFF file into JPEG file you need load annotations into memory:
images.Add("test.tif");
AnnotationDataController annoDataController = new AnnotationDataController(images);
// load annotations into memory - after this step encoder will be able to get "unpacked" annotations
// from memory and save annotations to the necessary format
AnnotationDataCollection annoDataCollection = annoDataController[0];
JpegEncoder jpegEncoder = new JpegEncoder();
jpegEncoder.AnnotationsFormat = AnnotationsFormat.VintasoftXmp;
images[0].Save("test.jpg", jpegEncoder);
mbauxd
Post by mbauxd »
Wow, thanks for the quick response!
Is there a way to bake these into the image using the SDK? Right now, I can only see the annotations when I open the JPG with the supplied tool.
Br
mbauxd
Post by mbauxd »
WpfAnnotationViewController wavc = new WpfAnnotationViewController(annoDataController);
wavc.BurnAnnotationCollectionOnImage(images[0]);
Nevermind, I got it using the above code. Thanks for the good support!
mbauxd
Post by mbauxd »
Sorry for reviving an old thread here, but there is another problem.
When converting TIFF files to PNG, rectangle annotations work fine (color/alpha and shape) but line annotations are not interpreted correctly. In the original, the lines are transparent with rounded corners, but in the result PNG produced via VintasoftImaging, these lines are NOT transparent and do not have rounded edges. While I personally don't care whether the edges are round or corners (and I'm pretty sure the customer won't either), the missing transparency causes these annotations to cover up important text.
Is this a known bug in version 8.3? Right now I unfortunately don't have access to the originals to attach an image, but maybe this description can already help.
Thanks!
Could you send us (to support@vintasoft.com) a small working project, which demonstrates your problem? We need reproduce the problem on our side.
mbauxd
Post by mbauxd »
I'll get some samples to you next week, when I have access to them again. Thanks for the response!
mbauxd
Post by mbauxd »
Small update, it will take another week for me to get you the samples, since I don't have the software needed yet, to create some sample files for you to use. Once I do, I will send them to you. Code wise, you can see the errors when opening the tiff in your own sample application, so I do not think, sending code is necessarily required.
The distributive package of VintaSoft Imaging .NET SDK does not have image files with WANG annotations. Please let me know the steps, which we should do for reproducing your problem.
mbauxd
Post by mbauxd »
Thats what I meant by preparing some sample files for you. As soon as I have them, I'll send them to you.
