I am trying to install a test application on 32 and 64-bit operating systems. It works perfectly on all 32-bit systems tested so far, but I can't get the Twain dll to work on the only 64-bit OS I have available (Windows Server 2008). The error message I'm getting is:
The stacktrace indicates that this is thrown when Vintasoft.Twain.VSTwain.StartDevice() is called.An attempt was made to load a program with an incorrect format. (Exception from HRESULT: 0x8007000B)
Have you tried this dll on 64-bit OS's? Is there a workaround or a plan to support 64-bit in the future?
Ian
