Vintasoft.Imaging.Ocr.Tesseract and Tesseract 4
David_karlsson
Post by David_karlsson »
Hi
Does Vintasoft.Imaging.Ocr.Tesseract plugin use Tesseract 4? If not, is it possible to do so?
Can I use multiple languages? In tesseract we can use eng+latin etc.
Re: Vintasoft.Imaging.Ocr.Tesseract and Tesseract 4
Hi David,
David_karlsson wrote: Mon Jan 14, 2019 3:47 pm Does Vintasoft.Imaging.Ocr.Tesseract plugin use Tesseract 4? If not, is it possible to do so?
Current version of Vintasoft OCR .NET Plugin uses Tesseract OCR 3.04. We plan to use Tesseract OCR 4 in near time.
David_karlsson wrote: Mon Jan 14, 2019 3:47 pm Can I use multiple languages? In tesseract we can use eng+latin etc.
Please read how to recognize text in two languages here:
https://www.vintasoft.com/docs/vsimagin ... uages.html
David_karlsson
Near time? 1 month ? 1 year?
I have already read the documentation. In the documentation it says how to OCR interpret different sections of a pdf with different languages.
In tesseract to do a better interpretation of same section (page) it is possible to combine different languages ex. eng+deu.
It can even be used with multiple languages traineddata at a time eg. English and German:
tesseract myscan.png out -l eng+deu
https://github.com/tesseract-ocr/tesseract/wiki
David_karlsson wrote: Mon Jan 14, 2019 9:52 pm Near time? 1 month ? 1 year?
Tesseract 4 will be available in version 8.7.2 in 2 months.
David_karlsson wrote: Mon Jan 14, 2019 9:52 pm I have already read the documentation. In the documentation it says how to OCR interpret different sections of a pdf with different languages.
Thank you for information. We will analyze information and will try to provide the best solution.
David_karlsson
Perfect. I will happily wait for release of Tesseract 4 plugin.
David_karlsson
Hi !
Is there any preview of version 8.7.2 ? We have started to develop our system. I need Vintasoft.Imaging.Ocr.Tesseract API for tesseract 4.
Is it possible to access Vintasoft.Imaging.Ocr.Tesseract 8.7.2 in advance?
Hi David,
David_karlsson wrote: Mon Feb 04, 2019 10:12 pm
I think preview version will be available in 2 weeks.
Hi David,
Version 8.7.2.1 has been released today. In this version the used Tesseract OCR engine has been updated to version 4.0.
Also in version 8.7.2.1 you can specify that text must be recognized in several languages. Here is an example that shows how to recognize text written in English and German languages: https://www.vintasoft.com/docs/vsimagin ... uages.html
