Stack Overflow exception in VintaSoft
I'am use Vintasoft.Twain dll in my application. And with scanner HP N6010 I have got the stack overflow exception. I get this exception only when I use Vintasoft, for exapmle if I use twain_32.dll then scan processed correctly. Also I have caught the problem with incorrect scanning results (this error also occurce only when I use Vintasoft dll).
Re: Stack Overflow exception in VintaSoft
Hello Sergey,
What version of VintaSoftTwain.NET Library do you use? Please try to use latest (4.2) version and let me know results. Also please send me a snippet of your code.
I'm using VintaSoft 4.2 library. And as application use the sample from Vintasoft site (TwainAdvanced), this sample is a part of VintaSoft Twain product. With all scanners this application works normally but except HP N6010. But I can say that this problem occurce in Vintasoft product, because if I use twain_32 windows dll all works correctly. And for example the photoshop also make scan operation correctly.
Please ganerate a log-file of scanner's work and send it to us. Here are steps which you should do:
1. Set the IsLoggingEnabled property to True before the StartDevice method.
2. Set the path to log-file with the LogFilePath property if path "c:\vstwain.log" is not accessible by your application.
3. Run your application.
4. Send a log-file to support@vintasoft.com.
Set vsTwain1.ShowIndicators = false before you acquire the image and it should be fine. It is a problem with the HP twain drivers.
