WPF DICOM Viewer Question
Harwold Groy
Post by Harwold Groy »
Hello~
In my wpfDicomviewer prj,
I did just modify short "logo" in the WpfAboutBoxBaseWindow.xaml.
(Replaced with exactly same .png file with VintaSoft logo.png pixel and file size) (Same png folder location in RESOURCE in WpfDemosCommonCode)
and then run in VS...
Any logo did not shown up.
(Even I've tried to same VintaSoft logo only change vintasoft logo's name and tried VintaSoft name and logo itself for recover)
And in the WpfAboutBoxBaseWindow.xaml.cs (This is my question...)
public partial class WpfAboutBoxBaseWindow : Window
    #region Constructors
    public WpfAboutBoxBaseWindow()
        InitializeComponent();
    public WpfAboutBoxBaseWindow(string productPrefix)
        : this()
        nameLabel.Content = string.Format(nameLabel.Content.ToString(), AssemblyTitle, AssemblyShortVersion);
        imagingSDKVersionLabel.Content = string.Format(imagingSDKVersionLabel.Content.ToString(), ImagingSDKVersion);
        productLinkLabel.Text = string.Format(productLinkLabel.Text.ToString(), productPrefix);
Some " InitializeComponent();", "imagingSDKVersionLabel" and some mores....
Red underlined~~~Ex) The name "nameLabel" does not exist in the current context
But I did not mistyped or mistake except image replacing~~
Can anyone help me?
Of course "using ~~~~" are all same~
Re: WPF DICOM Viewer Question
Please do the following steps:
  • Run Visual Studio.
  • Open VintaSoft DICOM Viewer Demo project ("[SdkInstallPath]\VintaSoft\Imaging .NET v12.4\Examples\WPF\CSharp\WpfDicomViewerDemo\WpfDicomViewerDemo.Net8.csproj") in Visual Studio.
  • Click the "WpfAboutBoxBaseWindow.xaml" and you will see "About" dialog in WPF designer.
  • Click on logo image and you will see XML markup for logo image:
    <Image Name="vintasoftLogoImage" HorizontalAlignment="Center" VerticalAlignment="Center" MouseDown="Image_MouseDown" Cursor="Hand" Source="{StaticResource VintasoftLogo}"/>
    Logo image uses static resource "VintasoftLogo":
        <Window.Resources>
            <BitmapImage x:Key="VintasoftLogo" UriSource="Resources/VintasoftLogo.png" />
        </Window.Resources>
Harwold Groy
Thank you for reply.
Excuse me but...
<Border x:Name="VintasoftLogo1" BorderBrush="Black" BorderThickness="1">
"VintasoftLogo1" is correct default?
Changed to "VintasoftLogo" is failed.
And for the "VintasoftLogo1", does not appear any my own logo~ picture.
Can you check it in your code?
I mean...
a)actual logo image => tried my own logo (failed to disply)+ vintasoft logo
(If changed file name, failed/keep original name? Succeeded vinta logo display)
b)name : Exactly same with "VintasoftLogo" but not sure <Border x : ~~~VintasoftLogo"1"?~~~~~>
  • Open PNG file "[SdkInstallPath]\VintaSoft\Imaging .NET v12.4\Examples\WPF\CSharp\WpfDicomViewerDemo\WpfDemosCommonCode\Resources\VintasoftLogo.png" in any image editor and change image, for example, flip image vertically.
  • Open origonal version of VintaSoft DICOM Viewer Demo project ("[SdkInstallPath]\VintaSoft\Imaging .NET v12.4\Examples\WPF\CSharp\WpfDicomViewerDemo\WpfDicomViewerDemo.Net8.csproj") in Visual Studio.
  • Compile and run the project.
  • Open "About" dialog and you will see that logo image is changed.
Test above shows how to change logo image in About dialog.
The "About" dialog is WPF dialog will source codes. If you want to change the dialog, please open it in WPF editor and change the dialog layout - this is custom programming operation and you need experience in WPF programming.
emmayashri
Post by emmayashri »
Hey hi, please double check that the nameLabel element is correctly defined in your XAML and that its name matches the one used in your code-behind file.
