ASP.NET Core: Load images from custom folder and display loaded images in web image viewer.
If you want to load images from custom folder (for example, from folder "C:\Images\") and display loaded images in VintaSoft web image viewer in ASP.NET Core application, you need to do the following steps:
  • Create custom data storage that allows to access files in custom folder - below you can see source codes of simple custom data storage that allows to access files in folder "C:\Images\".
  • Specify that Vintasoft Web API controllers should use created custom data storage to access image files.
Here is C# code of custom data storage that allows to access files in folder "C:\Images\":
using System.IO;
using System;
using Vintasoft.Data;
namespace AspNetCoreImagingDemo.Controllers
    /// Storage that allows to store data in database.
    /// <remarks>
    /// Current data storage works in read-only mode.
    /// </remarks>
    public class CustomDataStorage : IDataStorage
        static object _lockObject = new object();
        string _folderPath = @"C:\Images";
        public CustomDataStorage()
            : base()
        /// Determines whether the data storage can store data of specified type.
        /// <param name="type">The type of data.</param>
        /// <returns>
        /// <b>True</b> if data storage can store data of specified type;
        /// otherwise, <b>false</b>.
        /// </returns>
        /// <exception cref="System.ArgumentNullException">If <paramref name="type" /> is <b>null</b>.</exception>
        public bool CanStore(Type type)
            // specify that data storage can work only with images, which are stored in Stream objects
            if (typeof(Stream).IsAssignableFrom(type))
                return true;
                return false;
        /// Determines whether the data storage contains an item with the specified identifier.
        /// <param name="key">The item key.</param>
        /// <returns>
        /// <b>True</b> - the data storage contains an item with the specified identifier;
        /// <b>false</b> - the data storage does NOT contain an item with the specified identifier.
        /// </returns>
        /// <exception cref="System.ArgumentNullException">If <paramref name="key" /> is <b>null</b>.</exception>
        public bool Contains(string key)
            lock (_lockObject)
                // check if image with identifier "key" is stored in folder
                string fileName = Path.Combine(_folderPath, key);
                return File.Exists(fileName);
        /// Returns the keys of all items from data storage.
        /// <returns>The keys of all items from data storage.</returns>
        /// <remarks>Method can be not implemented if functionality is not necessary.</remarks>
        public string[] GetKeys()
            lock (_lockObject)
                // get identifiers ("keys") of all images stored in folder
        /// Returns an item copy from the data storage.
        /// <returns>The copy (clone) of item data.</returns>
        /// <exception cref="System.ArgumentException">Thrown if <paramref name="key"/> is not found.</exception>
        /// <exception cref="System.InvalidOperationException">If item with specified <paramref name="key" /> is locked.</exception>
        public object GetItemCopy(string key)
            lock (_lockObject)
                if (Contains(key))
                    // get image data from folder and return Stream object that contains image data
                    return new FileStream(fileName, FileMode.Open, FileAccess.Read);
                    throw new Exception(string.Format("Data storage does not have image with identifier \"{0}\".", key));
        /// Adds new item to the data storage.
        /// <param name="item">The item data.</param>
        /// <exception cref="System.ArgumentException">An element with the same key already exists in the data storage.</exception>
        public void AddItem(string key, object item)
            lock (_lockObject)
                // add image with identifier "key" in folder
        /// Sets the existing item in the data storage.
        public void SetItem(string key, object item)
            lock (_lockObject)
                // set image with identifier "key" in folder
        /// Deletes the item from the data storage.
        public void DeleteItem(string key)
            lock (_lockObject)
                // delete image with identifier "key" in folder
        /// Locks an item in data storage and returns the item.
        /// <returns>The locked item from data storage.</returns>
        /// <exception cref="System.ArgumentNullException">Thrown if <paramref name="key" /> is <b>null</b>.</exception>
        /// <exception cref="System.InvalidOperationException">Thrown if item with specified <paramref name="key" /> is already locked.</exception>
        /// <seealso cref="UnlockItem(string, object)"/>
        /// <remarks>Method must be implemented if image must be locked during changing.</remarks>
        public object LockItem(string key)
            lock (_lockObject)
                // lock image with identifier "key" in folder
        /// Unlock the locked item in data storage.
        /// <param name="item">Locked item.<br />
        /// The item will be overrwritten if item differs from the item returned by the <see cref="LockItem"/> method.</param>
        /// <exception cref="System.InvalidOperationException">Thrown if item with specified <paramref name="key" /> is not locked.</exception>
        /// <seealso cref="LockItem(string)"/>
        public void UnlockItem(string key, object item)
            lock (_lockObject)
                // unlock image with identifier "key" in folder
        /// Releases all resources used by the <see cref="DataBaseImageStorage"/>.
        public void Dispose()
Here is C# code of VintaSoft Web API controller that allows to work with image collection:
using Microsoft.AspNetCore.Hosting;
using Vintasoft.Imaging.AspNetCore.ApiControllers;
    /// A Web API controller that handles HTTP requests from clients and
    /// allows to manage an image collection.
    public class MyVintasoftImageCollectionApiController : VintasoftImageCollectionApiController
        /// Initializes a new instance of the <see cref="MyVintasoftImageCollectionApiController"/> class.
        public MyVintasoftImageCollectionApiController(IWebHostEnvironment hostingEnvironment)
            : base(hostingEnvironment)
        protected override IDataStorage CreateSessionDataStorage(string sessionId)
            // create custom data storage that allows to access files in folder "C:\Images\"
            return new CustomDataStorage();
Here is C# code of VintaSoft Web API controller that allows to work with Vintasoft images:
using System;
using Vintasoft.Imaging.Pdf;
    /// allows to get information about image or render image thumbnail/tile.
    public class MyVintasoftImageApiController : VintasoftImageApiController
        /// Initializes a new instance of the <see cref="MyVintasoftImageApiController"/> class.
        public MyVintasoftImageApiController(IWebHostEnvironment hostingEnvironment)
