Applying Brightness Contrast Command to a Figure
tplambeck
Is it possible to use the ChangeBrightnessContrastCommand to modify a figure before rendering the figure on a document? I am adding a PNG signature to a PDF delivery document captured on a mobile device. Sometimes the signatures are very faint and need to be darkened. Currently, I am adding them to the document, rendering them, and then reducing the brightness and increasing contrast on the full document to improve the quality of the signature. This darkens and sharpens the entire document which is not ideal. So, is it possible to add the figure, alter it's brightness and contrast, then render it or does the command have to be applied to everything in the viewer? Hope that makes sense and thank you for your assistance.
Re: Applying Brightness Contrast Command to a Figure
I think you need to render signature on transparent 32-bit RGBA image, change contrast/brightness and draw signature image on a document. Have you tried to do this?
tplambeck
That was something I was planning to try if changing the unrendered figure was not feasible. I will implement that, thank you.
